We have just installed AutoCAD 2015 and we are have problems on some PC with regeneration. Example , when an object is selected then deleted, the object is still visible on screen, once you pan or zoom out the object will only then remove from the screen. Hardware accelerations is on.
Is there any other variable that could affect this.
S
Solved by David_W_Koch. Go to Solution.
This may not help, but make sure REGENMODE is set to 1. (I tried setting it to 0, but erased objects still disappeared from the screen for me.)
There may be some interaction between the program and any special video card driver or control program that is running on that computer that is holding up the disappearance of erased items.
