Help my file is stuck in refedit mode. I can't select anything exept a couple of blocks and everything else is greyed out. I close and reopen the file and it is still the same. Audit and purge everything with no change. Regenall does not change the file.
Autocad architecture 2011
Win 7 pro 64 bit
Dell Precision T3500
Xeon 2.8 GHz
12.0 GB
refclose command does not work.
Found it. All the layers were locked except one. For some reason they stayed locked after closing the refedit command.
