AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
RECTANGLE @
4 REPLIES 4
240 Views, 4 Replies
RECTANGLE @
In ACA 2011, attempting to draw a retangle the command breaks when I enter the @ key.  I have tried all of the versions of this command, like rec, .rectang, etc.  Please help.
Tags (1)
4 REPLIES 4
pendean
Did this just start? Or has always done it?
Does entering @ in other commands do the same?
in reply to: pendean
I just loaded and began running 2011.  I just tried using the @ during the line command, although I never use line that way, and it aborted the command also.  Can you think of another command for me to try?
dseaton
I had a similar problem, in that you had to press @ twice to get it to register. This was resolved by the following:
Enable Dynamic Input by clicking DYN on the status bar, or by pressing F12.
Or
Disable Temporary Overrides by setting the TEMPOVERRIDES variable to 0.
Try that and see if that helps.
in reply to: dseaton
TEMPOVERRIDES = 0 works.  thank you.  Care to look at my other posts?  No one else ahve solved any of them.
”Boost
