81 Columbia Street
8 Floor Apt 8D
New York, NY 10002
EMail kencreightney@verizon.net
Phone 212-473-1682
Cell 917-406-3469
I Am Retired 88 years Old
Creightney Design INC Formerly Creightney Interiors
My Autocad is 2002 AutoDesk 3.3
I started 3 days ago drawing a Luxury Apartment for New York City I saved it several times and all of
a sudden it went blup It is gone, gone gone To see no more
What do I want ? For you to help me to replace it. Please. Please.
hi, go to command>options>files>and check where is the folder located for your .bak files. Rename .sv$ or .Bak to .dwg
or check which folder you originally saved your drawings and rename .bak or .tmp to .dwg.
Suggestion :
go to options>open and save>change the default from ac$ to sv$ and change automatic save to 10-15 minutes incase you encounter unexpected error you have latest files to retrieve.
please find attached for reference. hope it helps.
Thanks for the tip!! i was looking for the same file recovery things and alas found one.
