I printed drawing on my HP 9800 (11x17) black and white except for some random green line that does not show up in print preview, or in the drawing in model space or a layout.
I printed as a pdf also, and the random green line appeared too.
What could be going on? Why a random unknown printed object (UPO) when it is time to plot final drawings???
Help if you can.
ACA2011
win7 64
I think your UPO is really a UFO and if this problem persists you should contact NASA, FBI, CIA, FAA and a bunch of others cuz if you don't finish your project on time you'll be MIA if not DOA. (IMHO of course .... ROFLAO)
Just kidding.....
Can you isolate if this UPO is in model or paper space ? (move your viewport)
leothebuilder,
thanks....glad you got the joke
LOL,
Okay, I purged, and auditedthe drawing and tried to plot. Same UPO same place, both in a pdf and from printer.
The line does not show up in model space or any viewport. In fact it is not contained by any viewport.
When printing from model space the line does not show up. I have tried other layout tabs, 2out of 3 have the UPO. So the problem seems to be with layout tabs. So I will just delete them and creat new ones.
I created new layouts. SAME PROBLEM. However I notice that when I changed the drawing orientation from portrait to landscape the problem goes away.
So did a driver go postal or what?
Queue the Twilight Zone music for me too. I have the same problem in Civil 3D without a workable solution yet 😕
That just happened to me...got a random line somewhere in my drawing that didn't appear anywhere in model/paper views. After trying a couple of things I read off the web, I used REGEN and the rogue line mysteriously appeared in model view, so I was able to delete it. In case future users have the same problem 🙂
I came across a similar issue today. Random lines were printing in paper space but those lines were nowhere to be found.
I ran some tests:
1. I unloaded a model file and printed again, strange lines did not plot.
2. I reloaded the model file and printed again, strange lines came back.
3. I opened the model file, thawed / unisolated / turned all layers on. Did not find strange lines.
4. I went back to the sheet drawing, detached the model file, re-attached it and printed again. Strange lines have disappeared.
Not sure if it works everytime or just once in my case, but I hope it solves this problem for someone else.
Best regards!
