I'd like to use stairs and railing for a project but when I try to plot elevations and perspective views in legacy hidden viewports I am getting this effect where the railing is displayed but does not plot, yet hides objects behind it. I've changed materials without luck. Any advice would be helpfull. Thanks.
Without the drawing and your plot style table, it is hard to know what is going wrong.
Start by making sure the color or style applied to the object is set to plot under your CTB or STB.
If it isn't a plot style issue, start digging through the display manager to figure it out.
Hi Joe,
Are you working in AutoCAD Architecture 2014 or 2015?
This may be related to a known issue with curved geometry and Shade Plot. Could you please try the following, and let me know if the railing now plots?
Depending on your plot settings, you may find different combinations of Visual Style and Shade Plot that yield better results.
