The benefit in using Constructs even in a small project are immeasurable.
Here's how and why:
1. Small One Story Building: Have a Construct for the Exterior "Shell"
with the roof in this file as well.
2. Have a separate Construct for all the Interior "guts" of the building.
3. Xref Overlay these two together to "see" the relationships between
outside and in when drawing in the constructs. Use Project
Navigator to do this and just drag-and-drop files one into another.
4. The two constructs will "merge" together in Views to form the
different types of Plans you need (Floor Plan, Reflected Ceiling, Roof Plan,
etc....)
What are the benefits in this method?
1. You use just the Exterior "Shell" to generate your Exterior
Elevations. Without the Interior "guts" elevations are created quicker and
do not have to "hide" everything behind the exterior walls.
2. With experience and a little Display Rep. tweaking you can create a
Roof Plan "View" where the exterior walls are displayed as a single dashed
line and the roof is displayed. Again with the interior "guts" in a
separate file these objects do not get in the way of this plan type so you
don't have to mess with freezing layers etc....
Why use ACA "all the way?" We all paid almost $4k for the program so is it
not a waste of $$$ not squeeze every last drop from it?
But it takes longer to create a building using the ACA method! Wrong--Dead
Wrong! Using ACA Objects the way they were intended actually speeds drawing
creation. How? Because you put an object in one time and that object
generates both Plan and Section and Elevation Views. Change the Object and
all other views when updated change too.
To prove this for yourself try one simple test: Download the Toilet
partitions I posted in the thread "Need Interior Elevation Help--Please."
This was a facetious post with the intent of getting people to "think." The
files are in my last post in the thread.
Put them in a drawing and generate an interior elevation. Was that faster
then drawing them in Plan and then creating the elevations using linework.
Change them and update the elevation. Faster or Slower?
When people say it takes longer they speak out of ignorance. The key to ACA
is something we all need to keep doing all our life--take in knowledge! I
know architects that will pay to go to a boxed lunch AIA meeting so as to
get their CEU's and see a Power Point presentation that really is just a
sales pitch by a manufacturer but that same architect will not invest for
free in the tools of his trade.
Interestingly there is a side effect to all of this that will make everyone
here a lot happier. It is for this very reason that AutoCAD and ACA will
never be discontinued by Autodesk. It is because with the average user
knowing 20 or less commands they will never be ready for anything else.
The other power of ACA is the Library of styles--build it up, customize it
and use it.
Invest in yourself and learn.
DK
wrote in message news:5851549@discussion.autodesk.com...
" few firms..." i work at a firm that is on LT. I use acad and arch in
another office and find that it is very useful and much prefer this to LT.
At the LT office we have folks who never learned anything but 2d drafting
and lines. They tried to go use adt 2004 but this was met with much
resistance.
i have a question about Autocad Architecture 2008 - why and to what
benefit is breaking a building apart into constructs a good thing? i like
pretty much all of what I see but have not yet found a project where
breaking up the bldg such as the ext walls beyond layers is useful.
perhaps the answer is that the projects just aren't large enough.
I am searching for reasons to stick it out and try to use ACA "FULLY"
