AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Quadro FX3800 poor performance
2 REPLIES 2
1887 Views, 2 Replies
I just upgraded my video card from a Geforce 9800gt to a Quadro FX 3800 and I don't have the "performance increase" everybody is talking about. I have the latest driver for that card.
System info is
I7 960 cpu
12 gigs ddr3 ram
quadro fx 3800 video card
MSI x58 PRO-E motherboard
1200w power supply
Is there some setting that I have wrong or do I have a faulty video card?
Thanks in advance
2 REPLIES 2
DariuszWierzbowski6806
Have you A2010 or 2011 ? You should install performance driver for architectur/autocad . If you have a2011 , you should use opengl performance driver for quadro its 5x times or more faster than in 2010 . There no drivers openGl for A2010 with vista 64 or win7 64 and its problem beacause other drivers are slower than opgl . Also Switch off "vertical synchronization" / force  off / in Nvidia panel / Global 3d setings / . With performance quadro opgl you can use antyaliasing  edges without decreasing performance . J have q5800 and it works beatiful in A2011 . In A2010 increasing performance isnt so spectacular but satbility is much better and it is the most important with quadro . You can notice difference between GT and quadro working with big objects for example then you working with "seets" , changing drawing windows etc.
Darek from Poland
Where can I get the opengl performance driver? I'm using AutoCad Architecture 2011and on a 2 mb model it is very jerky and slow. I upgraded from a geforce 9800gt and there is no difference whatsoever.
Michael
”Boost
