AutoCAD Architecture General Discussion
Distinguished Contributor
jmartinarch
Message 1 of 6 (198 Views)
purge plotters
198 Views, 5 Replies
06-07-2011 04:50 PM
ACA 2011 Win 7 - 64
How do I purge or delete the printers/plotters from the list in the plot set up dialog.  I have several that go to the same machine but are not config'd correctly or just simply not used.  Can I get rid of them so I don't have to sort through when plotting?
Also,  what about the list of sheet set ups in the plot dialog? Can they be purged somehow?
Active Contributor
CivicDesignGroup
Message 2 of 6 (195 Views)
Re: purge plotters
06-07-2011 05:50 PM in reply to: jmartinarch
File > Plotter Manager. Delete the ones you don't use.
If you change plotter properties when you plot and it asks you if you want to save the setup, it will make a new one. Select No to keep that from happening.
jmartinarch
Message 3 of 6 (174 Views)
Re: purge plotters
06-08-2011 07:41 AM in reply to: CivicDesignGroup
There is only one listed. a .pc3 file.
When printing from other applications I notice these extra plotters (really copies of the same) too.  So I went to control panel - devices & printers and only one plotter is there. (along with my other devices).
Contributor jim
jim
Message 4 of 6 (167 Views)
Re: purge plotters
06-08-2011 08:03 AM in reply to: jmartinarch
browse to the folder "C:\ProgramData\Autodesk\ACA 2012\enu\Plotters" and delete any plotters in this folder that you don't use. it's best to make a copy of that folder's contents before you delete them in the eveny you delete tho wrong thing.
jmartinarch
Message 5 of 6 (163 Views)
Re: purge plotters
06-08-2011 08:24 AM in reply to: jim
Thanks,  however as I suspected once there I found only .pc3 files.  And only one for my plotter.  I think the problem may go beyond autocad as these "plotters" are available when I try to print from other applications as well.  :smileysad:
Contributor jim
jim
Message 6 of 6 (161 Views)
Re: purge plotters
06-08-2011 08:32 AM in reply to: jmartinarch
if you are seeing them in other applications then is an operating system issue rather than an autocad issue. look in your device manager to see if they are listed in there, if they are then you can probably remove them but be VERY careful as removing the wrong thing in there can cause some headaches.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
