AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Property Set Definitions - Pull Down List
2 REPLIES 2
FitzUS
407 Views, 2 Replies
Is it possible to create a pull down list of names for a manual Property Set Definition?
I'm placing names as a PSD of hatch objects to represent different department areas in a floor plan.  I will summarize these in a schedule that is exported to Excel.  For this reason I want to standardize certain names and have them selected from a list.
I would much rather uses Spaces for this purpose but I'm stuck using hatch patterns instead.
2 REPLIES 2
John.W.Mumaw
in reply to: FitzUS
Yes you can.  First you need to make a list definition (under multi-purpose objects in style manager).  Then on the definition tab of the property set definition, in the third column titled "Type" select list, and in the fourth column select the list definition you created.  When you create the list definition there's a check box at the top to let users vary property values if you so choose.
John
John W. Mumaw
Timber Frame Designer
Lost Bent Woodworking & Design
FitzUS
in reply to: John.W.Mumaw
Works great!
”Boost
