I clicked on my property pallate in ACA16 today to minimize it and and it has disappeared. when I try to open it up again I see the command on the command line but no pallatte. I need help retreiving it from the nether regions.
Solved by dbroad. Go to Solution.
Sometimes the palette goes to a 0 width when docked. Try hovering over the side you think it is docked on and look at your mouse cursor. If it changes, try dragging the properties palette width back to where it should be.
You're welcome. Glad to help. It confused me for a while as well.
If you don't want to be nagged by Autodesk and think that is a solution, be sure to mark the post that solved your issue.
