Hello:
Out of the blue, I can no longer open the Properties Palette when I double-click on something. Sometimes, I get the Quick Properties Box, instead -- which was already turned off. I've triple checked that the QP is off, made sure no tool tips or the like are on, and I've rebooted the computer, but I can't get rid of the thing.
The main Properties Palette still opens up when I use CTRL-1, if I type "properties" at the command prompt, and if I right-click and select "Properties" from the short-cut menu. Sounds great -- except when I double-click something out of habit and can't jump into the palette and keep going. Instead I have to clear out of whatever pops up on my screen and open the PP 'manually'.
I've gone in to the CUI and dragged "Properties" in to the double-click function, but...nada.
I'm hoping someone has a fix for this, because I am tired of burning time on it.
Thanks.
