AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Project navigator--sheet set ups
1 REPLY 1
silviaberian
272 Views, 1 Reply
Hi,  I am setting up sheets in the PN.  I already have my views with all my necesary xrefs attaches.  Since I have multible Sheets, i was trying to freeze certain layers in the xref in my view.  Now, xrefing the view into my sheet, all the layers i froze in my view do not show frozen in my sheet.  Do I have to freeze each layer in every sheet again?
Did I miss a step?
thank you
Silvia
1 REPLY 1
MarySeufert
in reply to: silviaberian
Check your Project's properties. Under Basic, Drawing Settings, is Match Sheet View Layers to View set to Yes?
Other things to check:
  • VISRETAIN should be set to 1
  • VPLAYEROVERRIDESMODE need to be set to 1
  • Make sure both drawings are part of the project
~ Mary
EXPERT ELITE MEMBER
”Boost
