Has anyone noticed that Project Navigator Elements do not retain their settings when dragondropping into another element?
Test 1: Create Element Drawing A with 2 objects on 2 separate layers. Turn off 1 of 2 layers and save.
Create Element Drawing B and dragondrop Element Drawing A into Element Drawing B.
All layers of Drawing A are on in Drawing B.
Test 2:Use Drawing A from above.
Xref Drawing B into Drawing A using Xref Manager.
Layer settings are retained; 1 layer is on, the other off.
?:Why?
Can Test 1 one be made to have same results as Test 2?
Is there a system variable or setting controlling this behavior?
