I have recently updated to 2012 and since doing so, when I open 2012 the profile is defaulted to Architecture 2012. I have to go into options and make mine current. I have searched and cannot find a way to make my profile default.
Any assitance would be gratly appreciated.
Solved by pendean. Go to Solution.
Unless you change it, by default all ACA versions start by calling an external profile file while loading: right-click over the icon you use to launch ACA and select Properties>Start In entry at the end I believe lists the profile being called.
