AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Productivity Pack for 2010 - Problems
8 REPLIES 8
Message 1 of 9
322 Views, 8 Replies
1) It cannot be uninstalled.
2) If corrupted, it cannot be re-installed.
3) Even if most or all of its files are deleted and if all registry entries
are deleted, it maintains it is configured for ACA 2010
8 REPLIES 8
Message 2 of 9
kari_sinkko
I'm not aware of an ACA pack? Is it a beta update?
Message 3 of 9
http://www.youtube.com/watch?v=fs7ucL1WX1o
Dean Saadallah
http://LTisACAD.blogspot.com
Message 4 of 9
Yes. See the link Dean posted. It has some nice tools. I wish I had a
cleanup tool so I could reinstall it.
wrote in message news:6289391@discussion.autodesk.com...
Message 5 of 9
Lineabove
Doug, would you mind seeing if you can perform a repair install of Architecture ?
Or at least do you still have the option ?
The reason I ask is that I an unable to.
I am wondering if the issue is the Productivity/Renovation Pack also.
Message 6 of 9
I did both a repair install to ACA 2010 and a full reinstall and still could
not reapply the productivity pack. Neither did the repair or reinstall fix
the productivity ribbon tab. Once the ribbon was messed up I couldn't get
it back.
wrote in message
news:6290115@discussion.autodesk.com...
Architecture ?
Message 7 of 9
Lineabove
Thanks Doug,
You answered my question but I am no closer to answering yours.
I am not able to do a REPAIR Install although you still can, so I do not believe the Productivity Pack had anything to do with my issue.
For your issue, when I look at my ADD or REMOVE Programs via the Control Panel there is a "Productivity for AutoCAD Architecture 2010" listed.
Does that help you at all ?
Message 8 of 9
Lineabove
Doug, I just discovered something else.
When I go to the Control Panel and have the "Show Updates" box checked.
I find that I have Autodesk Architecture Version 2 listed.
This does have a REMOVE button.
But, this may be the Service Pack 1.
Dunno
Does this help you at all ?
Message 9 of 9
I'll try. Thanks for checking.
wrote in message
news:6291016@discussion.autodesk.com...
Dunno
”Boost
