I've received an AutoCad dwg file that is 3D, but I can't seem to open it. What must I have in order to open it in 3D?
Thank you!
How big is the .dwg file? Also, what's the spec on the computer?
Just want to see is it a really big model or not.
The spec sound good. Should be just fine. I would try the recovery options first. Let us know if you will have issue after that.
by "3D" do you mean it was created with Autocad Architecture? or MEP?
