AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Problems Installing AutoCAD Architecture 2015
3 REPLIES 3
panayotis.ch
830 Views, 3 Replies
I have some problems that occured when i try to install Autocad Architecture 2015, and i would like to help me to solve them.
So, i am going to Autocad.com and i press the option Install Now at Autocad Architecture 2015..
In the Install Menu it says that is already installed..10699236_1495227157391459_1606514821_n.jpg
..ok..and i continue the proccess..but when i go to setup Autocad 2015 Architecture it occures an error..index.jpg
what can i do for this..?
Thanks in advance, Panayotis.
3 REPLIES 3
David_W_Koch
in reply to: panayotis.ch
Is AutoCAD Architecture 2015 already installed?  Have you checked on the Control Panel > Programs and Features > Uninstall or change a program to see if Autodesk AutoCAD Architecture 2015 is listed?
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
panayotis.ch
in reply to: David_W_Koch
I cannot find it at Programms and Features..It is not exist there..but when i go to install that ..it appears that..10699236_1495227157391459_1606514821_n.jpg
I don t know why..
David_W_Koch
If you previously had AutoCAD Architecture 2015 installed, or tried to install it but the installation failed without fully rolling back, you may want to take a look at this Autodesk Knowledge Network article on cleanly uninstalling AutoCAD (also applies to verticals - you will need to adjust the product name in certain directory paths).
David Koch
Blog | LinkedIn
”Boost
