I have some problems that occured when i try to install Autocad Architecture 2015, and i would like to help me to solve them.
So, i am going to Autocad.com and i press the option Install Now at Autocad Architecture 2015..
In the Install Menu it says that is already installed..
..ok..and i continue the proccess..but when i go to setup Autocad 2015 Architecture it occures an error..
what can i do for this..?
Thanks in advance, Panayotis.
I cannot find it at Programms and Features..It is not exist there..but when i go to install that ..it appears that..
I don t know why..
If you previously had AutoCAD Architecture 2015 installed, or tried to install it but the installation failed without fully rolling back, you may want to take a look at this Autodesk Knowledge Network article on cleanly uninstalling AutoCAD (also applies to verticals - you will need to adjust the product name in certain directory paths).
