I get the same error when publishing to pdf. I can plot one at a time, but cannot publish sets.
ERROR: Error saving PDF file; PDF file is open or uneditable
Which PDF driver are you using? (DWG to PDF, CutePDF, ...) Try a different one and see if that changes anything. There are lots of printer settings to double check when publishing to PDF.
I use Adobe PDF driver all the time without any problem when publishing but, as I said earlier, each driver has its quirks that must be thoroughly tested until understood. Start by plotting and then transition to publishing. The publishing dialog itself can be quite complex.
Hi
I am struggling with a similar issue.
It only creates a problem with some particular project sheets when Publishing (straight plotting to PDF works fine). Other jobs work OK. I do not not what to look for or change. And, why only with some projects?.
I'mrunning AutoCAD architecture 2016. and its been fine for many months. It now has a problem with sheets hat where fine before within same project.
Help please!
