Hi all,
is it possible to put an object on a tool pallete and pre-fill the property sets, so it comes carrying that info in a new drawing? i am trying to build an science equipement library on a tool pallete.
We can do it in a file, and then just copy out the relevent pieces, but it will be better on a pallete.
ACA 2009.
Thanks in advance.
-iova
Solved by David_W_Koch. Go to Solution.
If you are using AEC objects and can put your properties in a style-based Property Set, you can attach that Property Set to the AEC object style/definition and it will come along when brought in by a tool palette tool.
If you need or prefer an object-based Property Set (not using AEC objects or the properties have to be object-based), your only option would be to create the object, make an AutoCAD Wblock of the the object (a separate drawing file) and then have the tool insert and explode the block.
Iova:
Just my 2 cents. I'm creating casework libraries for our Interiors Dept. Plastic laminate, Wood, Science...
Using Multi-view blocks and Style based property sets (since information for my casework doesn't change). My opinion, I'll create the bigger library and set the information once, rather than the smaller library and having to edit property sets by Object over and over.
Next, set up a schedule to read the property sets so you have automated casework schedules. Add Qty and Unit Cost and you can do takeoff / cost estimation w/ your schedules.
