I'm using Autocad 2011 when plotting to the hp8150. I select the printer hp laserjet 8150 series pcl 6 select te paper size and the half size ctb and the program crashes with out printing my drawing.
The secon scenario if I select the hp laserjet 8100 series pcl 11x17.pc3, a dialogue box pop up requesting to update pc3 file with new printer. I select from the printer choices but it said device selected not found and it defaults to none.
Will someone let me know if this is a driver problem.
I'm able to plot with out any problem to the HP1050.
Solved by fajcisco. Go to Solution.
Solved by pendean. Go to Solution.
A guess: you are running Windows7 64bit? You must download and install HP's Universal printer Driver for Win7 for the problem to go away.
I have the same problem printing to a HP LJ 8150 from AutoCAD 2015.
I got our IT guys to install the HP universal printer driver (v5.1), but it still crashed AutoCAD.
We are using 32-bit systems.
I know this is an ancient printer, but it is very handy for printing labels from MS Word, etc and would be nice to use it for CAD check prints too.
Andy
Hi Andy,
For a workaround I would suggest printing to PDF from AutoCAD, and then printing to this particular printer.
To get the best answers to your issue please post in the Printing and Plotting forum.
