AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
PLN to DWG problems
1 REPLY 1
navidsidiqi
3768 Views, 1 Reply
PLN to DWG problems
Hi folks,
I am desperately in need of finding a solution for my problem....
I had an origional PLN (ArchiCAD) file  which I converted to DWG. I have been working for a long while but suddenly everything that I did in the new file is gone for some reasons. The new layers that I worked on are still there but I cant see anything in them.
Anyone can tell me what the problem could be if I have all the layers but no drawing on the screen. I should also add that they are not frozen/switched off
Any suggestions would be appreciated
1 REPLY 1
ntellery
in reply to: navidsidiqi
Is there a red light bulb bottom right of screen?  Have you isolated objects?  I've done that before, saved and opened the drawing later to find everything missing.
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://ausaca.blogspot.com.au/p/roof-object-video-links.html
”Boost
