I'm using Plant 3D drawings in an Architecture 2014 project. I made the Plant 3D drawing a construct in Architecture and then created a view using the Plant 3D construct and architecture constructs of walls and slabs to create a Plan View. Using the plan view I'm then cutting sections, successfully, and then placing the Plan view and section views into a sheet. The plan and section views appear correctly in the sheet created however when I go to print the layout the pipe fittings in the plan view do not show in the print. The pipes show but not the pipe fittings, valves, pipe supports.
Has anyone else come across this issue and have you been able to correct it?
There could be many reasons unless look at the drawing file. Quick things to check: you could try changing to any of the plot styles that are available by default. Also you may want to check the layer properties of the fitting if it's set to no plot.
