I'm trying to use Plan Elevation Labels. It works just fine in Metric but its completely screwed in Inches.
I created a basic 3D cube object.
I created a 1' high line. I use the Plan Elevation Label and when the pop-up box comes out, it will show the correct elevation of 1' 0" but when I hit OK, it shows +25'-4".
Am I missing something here? Pictures attached.
Thanks in advance for the help!
Welcome to the Discussion Groups!
Using the Imperial out-of-the-box content for Plan Elevation Labels [Plan Elevation Labels (3)], in a file started with one of the out-of-the-box imperial templates [Aec Model (Imperial Stb).dwt], the elevation label performed as expected.
Starting a file with a metric template [Aec Model (Metric Stb).dwt], and then changing the Units from millimeters to inches and the linear type from decimal to architectural (I did not rescale anything, when prompted), and using the imperial label, I did get results similar to yours (mine showed 25'-5", which would be consistent with a scale factor of 25.4, applied to 1'-0"). Even after changing the MEASUREMENT System Variable in that file to 0, purging the Multi-View Block and View Block for the elevation label and then re-inserting the plan label, I still got the incorrect measurement. It may be that your file had similar origins.
I am not sure what, if anything, could be done to a file started with a metric template to get it to not apply a scale factor to the label. You might be able to copyclip the contents of model space from your file and paste them into a new file started with an imperial template.
Thanks for your help. I figured it was something to do with the Metric to Imperial templates because it worked just fine when using Metric. Thank you, I'll look into it and post what I find out.
Okay, problem solved. There are 3 "versions" of Autocad Architecture when you install it. I used my start up menu to start mine and I guess it defaults to Metric. I have a mess of shortcuts on my desktop so I didn't notice the 3 Autocad Architecture icons and found the Imperial....
