AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
physical plotter in the pull down menu
2 REPLIES 2
tedwardspg
413 Views, 2 Replies
In the print dialog box, in the plotter pull down list, we only shows pc3 files instead of the physical plotter itself.
For example:
OCE700.pc3 and we do not show \OCE700\UPSTAIRS.
Every CAD system I have ever set up, I have never hidden the physical plotter and frankly I do not even know how to hide them. Is there a system variable that will allow me to see the physical plotter in the pull down the print dialog box, in the plotter pull down list, we only shows pc3 files instead of the physical plotter itself. For example: OCE700.pc3 and we do not show \OCE700\UPSTAIRS. Every CAD system I have ever set up, I have never hidden the physical plotter and frankly I do not even know how to hide them. Is there a system variable that will allow me to see the physical plotter in the pull down menu?
ACA 2013
Windows 7 enterprise
Intel core i7 860 @ 2.80GHz
16GB RAM
NVIDIA Quadro FX 1800 - 4GB
2 REPLIES 2
tedwardspg
in reply to: tedwardspg
There is a variable that I found. just FYI
HideSystemPrinters
ACA 2013
16GB RAM
pendean
... Or uncheck the box with the same name in the PLOT tab of OPTIONS command.
”Boost
