I am using Autocad Architecture 2015
i a looking for a video on how i am supposed to use the osnap command "From" now.
it does not work the way i am used to.
It works on lines, circles anything except ADT2015 entities.
Mitch
Osnaps on AutoCAD Architecture objects should work just like any other objects with a couple of exceptions. You can't snap to hatch on a wall for example, but you can snap to end points, midpoints, etc.
https://screencast.autodesk.com/Main/Details/c2758ffb-0e35-4343-bdf2-e50eb5fe18ab
Are you trying to snap to objects in a block or xref?
Should is a big word,
no i am not trying to snap to objects in a block or a xref.
I appear to be working correctly today.
