That doesn't seem to be my problem. If I stretch a structural element to
another and want to osnap to the opposite side of an other structural
object, case in point, two rim joist, then they osnap to the insertion
point.
"Nathan" wrote in message
news:6277323@discussion.autodesk.com...
> from my post in wishes
> "Can you please fix this up in 09. Not sure if it works in 10.
> If you layerisolate an ACA object that has ByMaterial selected, and the
> ByMaterial has the material layer for 3D display as 0, then you can no
> longer snap to the
> object.
> Not sure what other moves must be made for the osnaps to stop working,
> possibly a regen or redraw.
> To resolve requires you to change the material layer to the same as the
> object (so it's not off) which is NOT desirable.
> In order to use LayerIsolate, you must turn layer 0 back on and regenall
> to
> get the snaps to work again.
> This was not a problem in ADT6."
> This is repeatable for me consistently and I am surprised that it doesn't
> bother anyone else.
> I gather it happened when programming changes were made to the layer
> isolate tool
> (Can I have the old tool back please).
> "Nick Haury" wrote in message
> news:6277223@discussion.autodesk.com...
> Anyone?
> news:6276664@discussion.autodesk.com...
>> I have the "Allow general object snap settings to act upon wall
>> justification Line." unchecked, but if I try to stretch a structural
>> member
>> perpendicular to another, it want to snap to the insertion point. Why?
>> Nick
