When working with Roof Slabs, the view changes to a perspective view automatically. For me this is more difficult than the orthogonal view and I will get unexpected results when trimming or mitering slabs. I know that I can reset the view cube by going to the view tab and clicking on Top, but is there a switch or toggle that will prevent the view cube from going into perspective view? Thanks.
Hi Lisa,
Could you please post a short video or a sample file where this is happening, to clarify the issue?
Does this happen in every file? Every time? Or is the issue intermittent?
I bet this is a known bug that has not been fixed for several versions, pointed out by Odin at ArchiDigm.
http://www.archidigm.com/lounge/index.htm
Look over on the right column, ACA tips and tricks link.
Then scroll down to ACA2011 and ACA2011 Sky status bug.
It's because you have set views in perspective in your drawing previously and something doesn't get reset.
Autodesk have ignored it for ages.
Loading the attached lisp and typing SF will fix it.
