Can I arrange the ribbon and or quick access tool bar command drop down so that when I select a tool it stays in the top position rather then having to pick the drop down then scroll down and pick the tool.
So what ever tool I use stays in the top of the list.
I'm coming from adt04 so have no experience with the new cui interface.
Todd
Solved by jcp. Go to Solution.
Yes but it is slightly different between 2009 & 2010 (I haven't installed 2011 yet) In either program select the flyout button and in the properties look at the appearance section.
In 2009 look for Use Recent Command and set it to yes.
In 2010 look for Behavior and select one of the choices that include 'with Recent' in the description.
