AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Opacity of Layer Isolate
2 REPLIES 2
23643 Views, 2 Replies
The new layer isolate is great to work with. But with my previous version, all the layers turned off. Now the layers are grayed in color or translusent. How do I make the background darker so I can see my insolated layer more clearly.
IndyCadJocky
2 REPLIES 2
Once you start the LAYISO command, take a look at the Command: line, and note the Settings option. Type S and then [Enter] and you will be given the option to either turn Off or to Lock and fade the unisolated layers. Off works like the "old" LAYISO; if you select Lock and fade, you can enter a fade value between 0 (no fading) and 90 (maximum fading).
David Koch
Autodesk Discussion Group Facilitator
Using ADT 2004 at work; access to 2005, 2006, 2007 & 2008 at home
rpkulczak
Still works for LT 2019
”Boost
