I have two viewports in one layout. Both viewports' shadeplot setting is set to "Rendered". Rendering presets are set to "Draft" When I "publish", the right veiwport only shows the top 1/3 of the drawing and the right veiwport is blank. If I set Shadeplot to "Realistic", then the layout publishes correctly.
Any ideas on what I need to get things published correctly when Rendered?
