AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
object property autocad 2013
4 REPLIES 4
245 Views, 4 Replies
After sellecting the line ,the " LENGTH" in the object property can't be highlighted and modified. Although there are other values in the panel that are not locked and can be modified. what would be the reason.
4 REPLIES 4
dbroad
Which end would AutoCAD elongate?  To change length use the lengthen command.
Architect, Registered NC, VA, SC, & GA.
in reply to: dbroad
thanx for your reply.
but trying to modify the length from the property panel as i explained. the LENGH is not clickable unlike the other values in the panel.
dbroad
Perhaps you misunderstood my reply.  I was explaining why AutoCAD will not accept entry for changes in length for lines.  If you want to change the length of the line, use the lengthen command.  Given your illustration though, I would suggest changing your view to an orthographic elevation view and using the stretch command to change the entire figure.  If the object had been a wedge solid, you could have changed the height.
in reply to: dbroad
DBROAD;
YOU HAVE BEEN VERY HELPFULL. THANKS.
”Boost
