In the past I've tried various ways of drawing batt insulation and recently came up with a way that works very well for me. I used a Batt Insulation hatch as the main part of a dynamic block. I made the hatch associative with a boundary on the defpoints layer. I added grips for moving, rotating, scaling and stretching it. The dynamic block is sized so that the initial insertion of 1 would equal a width of 1 unit. In other words, at inserting it at a scale of 1 for imperial units will make a batt that is 1" thick. This allows you to type in the desired width of the batt on insertion (e.g. typing in 5.5 will give you a 5-1/2" thick batt to fit in a 2x6 wall). The basepoint grip in the bottom left corner allows you to move the block and is the basepoint for the rotation grip. The stretch grip pointing UP opposite the rotation grip allows you to scale the batt. The stretch grip nearest the basepoint allows you to stretch that side of the batt while maintaining the end angle. The grip at the right bottom (inline with the basepoint and rotation grips) allows you to stretch the other end of the batt while maintaing the end angle. The stretch grip in the corner above it allows you to adjust the end angle. You'll want to scale the width to the correct size before adjusting the length/angles as the scaling changes those other lengths. I appreciate the help I've received from others here in the past. Attached is the block.
Solved by David_W_Koch. Go to Solution.
Solved by dbroad. Go to Solution.
Solved by Libbya. Go to Solution.
David,
I see you have a very useful tool pallet full with details and tools you'll use to create your drawings. Was this something you created your self? or was it provided by a third party software?
Thanks!
Brian
@rubiobr10: The tool palettes shown in the posted Screencast are out-of-the-box palettes that come with AutoCAD Architecture, when installing the US Imperial content. Similar palettes are included with the US Metric content. Available palettes for the content in other regions may vary.
For what it is worth, on my work computer, I have a boatload of custom palettes, both standard palettes/tools for my office as well as ones I made for my own use.
Libbya,
I found your DB for insulation while searching for a way to work with the insulation linetype, which I was having trouble with scaling within multiple paperspace vewports. I am a huge fan of Dynamic Blocks, so I will be using your block.
I downloaded the second version, and I have a couple of comments:
1. Can you find your the .pat file that has your insulation hatch, and copy out the text for your Batt_Insulation pattern, starting with *BATTS_ , and ending just before the next *
- The hatch is not in our acad.pat file. Please copy/ paste the text into a reply, if you're still out there.
2. I find it helpful to actually name the actions within a DB, so they mean something in the Properties Palette, instead of simply "Linear1" etc.
3. I modified your version, and made the length a clean 2" to start with, and named the Actions as best as I could figure. I usually give overall Length Parameters an Increment, because I abhor random decimals.
Thanks for posting!
Batt_Insulation is not part of acad.pat in AutoCAD Architecture, either. It is one of a number of architectural hatches that ships with AutoCAD Architecture as standalone hatch files.
;;;; Copyright (c) 2003 GlobalCAD Consultants Ltd. ;; Hatch Manager and Linetype Wizard are trademarks of ;; GlobalCAD Consultants Ltd. All rights reserved. ;; Website www.globalcad.com *Batt_Insulation,Batt Insulation 0, 0.334111,0, 0.334111,1.125, 0,-0.334111 14.0764, 0.167055,0.125, 0.324078,-0.081261, 0.081268,-32.297418 14.0764, 0.167055,1.25, 0.324078,-0.081261, 0.081268,-32.297418 14.0764, 0.167055,2.375, 0.324078,-0.081261, 0.081268,-32.297418 14.0764, 0.167055,3.5, 0.324078,-0.081261, 0.081268,-32.297418 14.0764, 0.167055,4.625, 0.324078,-0.081261, 0.081268,-32.297418 14.0764, 0.167055,5.75, 0.324078,-0.081261, 0.081268,-32.297418 14.0764, 0.167055,6.875, 0.324078,-0.081261, 0.081268,-32.297418 25.0456, 0.205972,1.06513, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,2.19013, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,3.31513, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,4.44013, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,5.56513, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,6.69013, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,7.81513, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,8.94013, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,10.0651, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,11.1901, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,12.3151, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,13.4401, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,14.5651, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,15.6901, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,16.8151, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,17.9401, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,19.0651, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,20.1901, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,21.3151, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,22.4401, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,23.5651, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,24.6901, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,25.8151, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,26.9401, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,28.0651, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,29.1901, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,30.3151, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,31.4401, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,32.5651, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,33.6901, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,34.8151, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,35.9401, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,37.0651, 0.302695,-0.141442, 0.141438,-90.211539 25.0456, 0.205972,38.1901, 0.302695,-0.141442, 0.141438,-90.211539 52.4353, 0.245883,0.144768, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,1.26977, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,2.39477, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,3.51977, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,4.64477, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,5.76977, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,6.89477, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,8.01977, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,9.14477, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,10.2698, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,11.3948, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,12.5198, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,13.6448, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,14.7698, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,15.8948, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,17.0198, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,18.1448, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,19.2698, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,20.3948, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,21.5198, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,22.6448, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,23.7698, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,24.8948, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,26.0198, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,27.1448, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,28.2698, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,29.3948, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,30.5198, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,31.6448, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,32.7698, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,33.8948, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,35.0198, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,36.1448, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,37.2698, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,38.3948, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,39.5198, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,40.6448, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,41.7698, 0.203693,-0.264838, 0.137381,-55.213811 52.4353, 0.245883,42.8948, 0.203693,-0.264838, 0.137381,-55.213811 67.0616, 0.0307825,0.498153, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,1.62315, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,2.74815, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,3.87315, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,4.99815, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,6.12315, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,7.24815, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,8.37315, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,9.49815, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,10.6232, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,11.7482, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,12.8732, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,13.9982, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,15.1232, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,16.2482, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,17.3732, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,18.4982, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,19.6232, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,20.7482, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,21.8732, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,22.9982, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,24.1232, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,25.2482, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,26.3732, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,27.4982, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,28.6232, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,29.7482, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,30.8732, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,31.9982, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,33.1232, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,34.2482, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,35.3732, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,36.4982, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,37.6232, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,38.7482, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,39.8732, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,40.9982, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,42.1232, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,43.2482, 0.130217,-0.307691, 0.255844,-48.608113 67.0616, 0.0307825,44.3732, 0.130217,-0.307691, 0.255844,-48.608113 74.891, 0.177055,0.957945, 1.08611,0.293238, 0.111013,-12.707085 74.891, 0.511166,0.957945, 1.08611,0.293238, 0.111013,-12.707085 74.891, 0.845277,0.957945, 1.08611,0.293238, 0.111013,-12.707085 74.891, 1.17939,0.957945, 1.08611,0.293238, 0.111013,-12.707085 74.891, 1.5135,0.957945, 1.08611,0.293238, 0.111013,-12.707085 74.891, 1.84761,0.957945, 1.08611,0.293238, 0.111013,-12.707085 74.891, 2.18172,0.957945, 1.08611,0.293238, 0.111013,-12.707085 74.891, 2.51583,0.957945, 1.08611,0.293238, 0.111013,-12.707085 74.891, 2.84994,0.957945, 1.08611,0.293238, 0.111013,-12.707085 74.891, 3.18405,0.957945, 1.08611,0.293238, 0.111013,-12.707085 83.2526, 0.130483,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 0.464594,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 0.798705,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 1.13282,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 1.46693,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 1.80104,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 2.13515,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 2.46926,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 2.80337,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 3.13748,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 3.47159,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 3.8057,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 4.13981,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 4.47392,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 4.80804,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 5.14215,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 5.47626,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 5.81037,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 6.14448,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 6.47859,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 6.8127,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 7.14681,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 7.48092,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 7.81503,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 8.14915,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 8.48326,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 8.81737,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 9.15148,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 9.48559,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 9.8197,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 10.1538,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 10.4879,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 10.822,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 11.1561,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 11.4903,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 11.8244,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 12.1585,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 12.4926,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 12.8267,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 13.1608,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 13.4949,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 13.829,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 14.1631,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 14.4973,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 14.8314,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 15.1655,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 15.4996,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 15.8337,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.2526, 16.1678,0.733771, 1.11721,0.132179, 0.225743,-139.11436 83.8584, 0.00447135,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 0.338582,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 0.672693,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 1.0068,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 1.34092,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 1.67503,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 2.00914,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 2.34325,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 2.67736,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 3.01147,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 3.34558,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 3.67969,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 4.0138,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 4.34791,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 4.68202,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 5.01614,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 5.35025,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 5.68436,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 6.01847,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 6.35258,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 6.68669,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 7.0208,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 7.35491,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 7.68902,0.253664, 1.11854,0.12036, 0.245901,-77.827203 83.8584, 8.02313,0.253664, 1.11854,0.12036, 0.245901,-77.827203 276.142, 0.303328,0.498153, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,1.62315, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,2.74815, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,3.87315, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,4.99815, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,6.12315, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,7.24815, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,8.37315, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,9.49815, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,10.6232, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,11.7482, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,12.8732, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,13.9982, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,15.1232, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,16.2482, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,17.3732, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,18.4982, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,19.6232, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,20.7482, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,21.8732, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,22.9982, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,24.1232, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,25.2482, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,26.3732, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,27.4982, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,28.6232, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,29.7482, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,30.8732, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,31.9982, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,33.1232, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,34.2482, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,35.3732, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,36.4982, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,37.6232, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,38.7482, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,39.8732, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,40.9982, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,42.1232, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,43.2482, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,44.3732, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,45.4982, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,46.6232, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,47.7482, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,48.8732, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,49.9982, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,51.1232, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,52.2482, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,53.3732, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,54.4982, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,55.6232, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,56.7482, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,57.8732, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,58.9982, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,60.1232, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,61.2482, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,62.3732, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,63.4982, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,64.6232, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,65.7482, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,66.8732, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,67.9982, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,69.1232, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,70.2482, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,71.3732, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,72.4982, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,73.6232, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,74.7482, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,75.8732, 0.0357454,0.332193, 0.245901,-77.827203 276.142, 0.303328,76.9982, 0.0357454,0.332193, 0.245901,-77.827203 276.747, 0.177055,0.957945, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,2.08294, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,3.20794, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,4.33294, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,5.45794, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,6.58294, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,7.70794, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,8.83294, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,9.95794, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,11.0829, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,12.2079, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,13.3329, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,14.4579, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,15.5829, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,16.7079, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,17.8329, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,18.9579, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,20.0829, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,21.2079, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,22.3329, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,23.4579, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,24.5829, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,25.7079, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,26.8329, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,27.9579, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,29.0829, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,30.2079, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,31.3329, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,32.4579, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,33.5829, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,34.7079, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,35.8329, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,36.9579, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,38.0829, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,39.2079, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,40.3329, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,41.4579, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,42.5829, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,43.7079, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,44.8329, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,45.9579, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,47.0829, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,48.2079, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,49.3329, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,50.4579, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,51.5829, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,52.7079, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,53.8329, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,54.9579, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,56.0829, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,57.2079, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,58.3329, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,59.4579, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,60.5829, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,61.7079, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,62.8329, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,63.9579, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,65.0829, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,66.2079, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,67.3329, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,68.4579, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,69.5829, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,70.7079, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,71.8329, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,72.9579, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,74.0829, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,75.2079, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,76.3329, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,77.4579, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,78.5829, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,79.7079, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,80.8329, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,81.9579, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,83.0829, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,84.2079, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,85.3329, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,86.4579, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,87.5829, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,88.7079, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,89.8329, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,90.9579, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,92.0829, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,93.2079, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,94.3329, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,95.4579, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,96.5829, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,97.7079, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,98.8329, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,99.9579, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,101.083, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,102.208, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,103.333, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,104.458, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,105.583, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,106.708, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,107.833, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,108.958, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,110.083, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,111.208, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,112.333, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,113.458, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,114.583, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,115.708, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,116.833, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,117.958, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,119.083, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,120.208, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,121.333, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,122.458, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,123.583, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,124.708, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,125.833, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,126.958, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,128.083, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,129.208, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,130.333, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,131.458, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,132.583, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,133.708, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,134.833, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,135.958, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,137.083, 0.0392556,0.331797, 0.225743,-139.11436 276.747, 0.177055,138.208, 0.0392556,0.331797, 0.225743,-139.11436 285.109, 0.128139,1.06513, 0.0870879,0.322561, 0.111013,-12.707085 285.109, 0.128139,2.19013, 0.0870879,0.322561, 0.111013,-12.707085 285.109, 0.128139,3.31513, 0.0870879,0.322561, 0.111013,-12.707085 285.109, 0.128139,4.44013, 0.0870879,0.322561, 0.111013,-12.707085 285.109, 0.128139,5.56513, 0.0870879,0.322561, 0.111013,-12.707085 285.109, 0.128139,6.69013, 0.0870879,0.322561, 0.111013,-12.707085 285.109, 0.128139,7.81513, 0.0870879,0.322561, 0.111013,-12.707085 285.109, 0.128139,8.94013, 0.0870879,0.322561, 0.111013,-12.707085 285.109, 0.128139,10.0651, 0.0870879,0.322561, 0.111013,-12.707085 285.109, 0.128139,11.1901, 0.0870879,0.322561, 0.111013,-12.707085 285.109, 0.128139,12.3151, 0.0870879,0.322561, 0.111013,-12.707085 292.938, 0.203628,0.733771, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,1.85877, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,2.98377, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,4.10877, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,5.23377, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,6.35877, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,7.48377, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,8.60877, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,9.73377, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,10.8588, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,11.9838, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,13.1088, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,14.2338, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,15.3588, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,16.4838, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,17.6088, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,18.7338, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,19.8588, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,20.9838, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,22.1088, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,23.2338, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,24.3588, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,25.4838, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,26.6088, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,27.7338, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,28.8588, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,29.9838, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,31.1088, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,32.2338, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,33.3588, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,34.4838, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,35.6088, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,36.7338, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,37.8588, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,38.9838, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,40.1088, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,41.2338, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,42.3588, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,43.4838, 0.130217,0.307691, 0.255844,-48.608113 292.938, 0.203628,44.6088, 0.130217,0.307691, 0.255844,-48.608113 307.565, 0.00447135,0.253664, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,1.37866, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,2.50366, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,3.62866, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,4.75366, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,5.87866, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,7.00366, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,8.12866, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,9.25366, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,10.3787, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,11.5037, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,12.6287, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,13.7537, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,14.8787, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,16.0037, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,17.1287, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,18.2537, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,19.3787, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,20.5037, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,21.6287, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,22.7537, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,23.8787, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,25.0037, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,26.1287, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,27.2537, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,28.3787, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,29.5037, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,30.6287, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,31.7537, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,32.8787, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,34.0037, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,35.1287, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,36.2537, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,37.3787, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,38.5037, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,39.6287, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,40.7537, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,41.8787, 0.203693,0.264838, 0.137381,-55.213811 307.565, 0.00447135,43.0037, 0.203693,0.264838, 0.137381,-55.213811 334.954, 0,1.125, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,2.25, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,3.375, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,4.5, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,5.625, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,6.75, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,7.875, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,9, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,10.125, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,11.25, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,12.375, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,13.5, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,14.625, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,15.75, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,16.875, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,18, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,19.125, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,20.25, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,21.375, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,22.5, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,23.625, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,24.75, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,25.875, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,27, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,28.125, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,29.25, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,30.375, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,31.5, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,32.625, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,33.75, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,34.875, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,36, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,37.125, 0.302695,0.141442, 0.141438,-90.211539 334.954, 0,38.25, 0.302695,0.141442, 0.141438,-90.211539 345.924, 0.0882278,0.144768, 0.324078,0.081261, 0.081268,-32.297418 345.924, 0.0882278,1.26977, 0.324078,0.081261, 0.081268,-32.297418 345.924, 0.0882278,2.39477, 0.324078,0.081261, 0.081268,-32.297418 345.924, 0.0882278,3.51977, 0.324078,0.081261, 0.081268,-32.297418 345.924, 0.0882278,4.64477, 0.324078,0.081261, 0.081268,-32.297418 345.924, 0.0882278,5.76977, 0.324078,0.081261, 0.081268,-32.297418 345.924, 0.0882278,6.89477, 0.324078,0.081261, 0.081268,-32.297418
Since posting this thread almost 6 years ago I have updated the block in various ways. One of the ways was to create a custom hatch pattern that IMO looks a lot better. See screencast. One thing that I forgot to show in the screencast is that in properties, you can enter the number of units for the width and it will update accordingly. Unfortunately changes in width skew the end angles so set the width first. Attached is the block and custom hatch.
EXCELLENT!
I am constantly tweaking my own DB's, and I'm glad you included the hatch pattern too.
No way I wanted to use the previous one. Yours is much shorter.
Thanks!
Hi, can you explain how to created the batt insulation as a hatch? i have similar but not sure how to create the hatch part. thanks.
@cb94030 wrote:
How do I put this batt insulation in my Tools Palette?
Thank you.
There are various ways, but a simple way is to archive a file that contains the block in an accessible location and then drag the block onto whatever tool palette you would like it on.
I'm not sure I understand the question. The hatch is part of a dynamic block. The hatch is associative and the boundary is stretched/scale of hatch is changed dynamically.
@3darch2 wrote:
This is ridiculous to have to do this to get a line type. wth are they doing to acad.
I have used the linetype for batt insulation before and I vastly prefer this method.
Even more ridiculous than 'having to do this to get a line type' is popping onto a thread and posting offering no useful input and griping about the free things that someone else is offering. WTH are you doing?!
