AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
My ribbon is in gray and don't function until restart Architecture 2010
4 REPLIES 4
rmendezb
511 Views, 4 Replies
Frecuently my ribbon is in gray and don't function until restart Architecture 2010. It happen when I'm working, no moore than few minutes, and only my ribbon crash. I can work with command line, and the palettes , but don´t with ribbon.
4 REPLIES 4
in reply to: rmendezb
If you type RIBBON, does it come back?
Dean Saadallah
http://LTisACAD.blogspot.com
Did you load the old ACA menus? I've had this problem, too. Usually I
can switch to a different workspace and then back.
Sounds lile acad.cuix is loaded with aca.cuix. When both are loaded, mtext
text command causes the ribbon to grey out. Verify if mtext is causing this,
if so, get rid of acad.cuix.
This is discussed frequently in the newgroup, search for more information.
Mark
"Bill Gilliss" wrote in message
news:6350495@discussion.autodesk.com...
rmendezb
Thankyou.
Yes mtext is causing the trouble.
i recall workspace and the ribbon is enable again.
”Boost
