All,
I have since installing AA 2008 noticed that OSNAP does not work;
a) As it used to
b) In hidden mode
On the attached file there are two viewports, the one on the right is in 2D wire and on the left in 3D hidden. On the left viewport it is not possible to get OSNAP to select any point on the window, on the right viewport for some reason "perpendicular" has a greater priority than "end point" when trying to select a corner and I'm stumped. Basically I have to forget the settings and "force" the active command to select an endpoint, midpoint, intersection etc..
In addition I/we have noticed that OSNAP or the magnet function appears to be disabled during certain editing sub menus etc.
My UK reseller has acknowledged these bugs but I am still no further forward. It is now taking longer to do the job with AA 2008 than it used to with ADT 2006 which doesn't bode well when Autodesk have just sent us a subscription renewal notice.
Anyway has anyone else noticed this behaviour and can anyone offer a solution?
Regards
Ben
