AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Muntin Disply on Triple Sliding Door
3 REPLIES 3
VaDesigner10
903 Views, 3 Replies
Am trying to add a muntins display to the triple sliding door... it only gives me (2) glass panels instead of (3)... what am I missing here?
3 REPLIES 3
MarySeufert
in reply to: VaDesigner10
Check Door Style Properties-> Design Rules Tab-> Door Type should have Sliding Triple selected. Then adding Muntins should look like this:
I'm running 2012 at work so I can't check out your drawing...Smiley Embarassed
EXPERT ELITE MEMBER
ntellery
When I open your drawing and edit the style, double clicking on the bold model, selecting the 2nd tab Muntins and edit,
I can see the Lights have 2 wide.  You want to change that to 3 wide.
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://ausaca.blogspot.com.au/p/roof-object-video-links.html
VaDesigner10
in reply to: ntellery
Doh!  I should have picked that up.  Thank you.
”Boost
