Is ther a way to change the swing angle on more than one door at a time ?
the option is left out of "properties"
Which version are you using? In 2012 when I select multiple doors the swing angle still shows in the properties palette.
John
ACA 2012
That works only if all the doors are the same style.
It's a non issue, worked arounfd it. thanks though
Glad you figured out a work-around. Looking more closely at the issue; if I select two doors of different styles I still see "swing angle" available as long as swing angle applies to both styles. But if I choose a style, like a sliding door, where "open percent" instead of "swing angle" applies and a door where "swing angle" applies then neither are available. I guess I can see why that is, since sliding doors don't swing. But what might be nice is if "open percent" applied to all doors (since all doors open, but not all doors swing), and still remained available for editing when multiple doors of multiple door types were selected. Something for the wish list.
John
