AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Multiple cut planes in same wall
4 REPLIES 4
367 Views, 4 Replies
ACA 2008
I've got a stairwell wall that contains multiple windows that essentially
follow the slope of the stairs down. In plan I want to see all
windows...some are above the cut plane and some are below. I could use
separate walls that in plan clean up, but then there will be vertical lines
in the model and the elevations where those seams are.
Help?
Scott
4 REPLIES 4
Dushie123
Ditto
Dushie123
Ditto
info
in reply to: Dushie123
Hope the attached will be helpful. Project level cut planes and constructs might be different for walls, curtain walls etc.
faugustom
in reply to: info
- Uncheck the window style or object display option to "Use Cut Plane....";
- Set the wall cut plane to intersect the lowest window (using 'cm' as unit here);
- Check the wall style or object display option to "Hide lines below...";
- Result
”Boost
