AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
multiple buildings in the same project
4 REPLIES 4
aluko0719
2770 Views, 4 Replies
if a project has more than one building and the buildings have different level heights how would you go about setting that up in the project navigator? example.
project name: adam commercial site
project number: 14000
total of 4 buildings on the site.
Building no. 1 - manufacuture building, 3 levels 10' for each level.
Building no. 2 - warehouse, 2 levels, 15' for each level.
Building no. 3 - office building, 4 levels, 12' for each level
Building no. 4 - garage, 2 levels, 13' for each level.
this is all going to be built in one contract
drawings would be for each displine A-001 thru A-100, ect.
4 REPLIES 4
Keith.Brown
in reply to: aluko0719
Just prefix your level names with the name and/or the number of the building and then for each drawing assign to the appropriate level.  Just make sure to uncheck Auto Adjust Elevation.
aluko0719
in reply to: Keith.Brown
that a good idea.
would you use divisions as a building name or just have one division?
Keith.Brown
Buildings as a division name works just fine.  If you have multiple divisions withing a building then again just use the building name as a prefix to the division.
VitalyF
Additionally, you must use "UCS" for each building and
dwf map underlay...
”Boost
