Hello
In the property sets assigned to a multi -views block can retrieve it from the given set of properties of space thanks to the location property
my question is do the opposite just to recover given the multi-views block into space
Thank you for your help
I'm not exactly sure what you're asking.... however you can select a Multi-View Block OR the space it is attached to (for example) and modify it's attributes either way.
Is that what you were asking?
Not without some serious customization. Location properties only work to pull property data from a Space or an AEC Polygon to an AEC object.
Then again, it depends on what you are after, exactly. If you want one or more properties on a Space or AEC Polygon to report the Multi-View Blocks that fall within the footprint of the Space/AEC Polygon, then that would require customization. But if adding Location properties to the Multi-View Blocks to read in the room name and room number from a Space/AEC Polygon, and then setting up a Schedule Table that lists all of the Multi-View Blocks, grouped by Room Name/Room Number, then yes, you can do that.
My problem is that I have areas that I name workstation.
In this space I was up a multi view block a person.
As there is a person in the workspace occupies the position as it is there is no person is free
So this is the view that multi block reference information in this space
thank you
