I am using AUTOCAD ARCHITECTURE 2012, I 'm working in metrtics units, but I'm inserting imperial multi-view blocks because metric blocks are limited. When I see them in 3d view the blocks are deformed, but only the casework, sofa and table items. Someone knows why??...
Thanks!
possibly they haven't scaled evenly in x,y, or z direction.
ie, they would need to scale (25.4 I think) to be correct for metric drawing.
Check in the properties pallete.
It would help if you could post a sample file or at least some specifics to reproduce.
Thanks, I have tried that but the block only increments its size in the same proportion. I am attaching a view. This are sofas, tables & a base cabinet.
Thanks.
I don't get much from an isometric view in a pdf without annotations. Which blocks are problematic or exhibit scaling issues. It would be better to post a similar dwg file with a few notes. Is it the display style you object to?
I am attaching a dwg example file where there are some 3d furniture multi-view blocks. The parts of each one of these are in wrong place.
Thanks for your help.
Best guess: Probably a poor implementation of the "Scale Objects Inserted From Other Drawings".
Thing to try: Use the Units command to uncheck that setting. Insert the mvblocks from the imperial drawings. See if there is any difference. They will all be too small but might be non-deformed. If that works, you could try scaling things up manually (25.4 if using millimeters). It's probably the nested blocks that are causing the problems.
Thanks. I did your recomedation but it doesn't work, I dont' know what's happening. When I insert a new mvblock, it deforms, but when I insert it from another drawing (an adt 2007 one) it doesnt' deform.
Again, this is only an educated guess: Mvblocks are not themselves blocks but a collection of blocks with rule systems about how those blocks show up. The location of a nested block needs to be scaled or adjusted, not just the geometry within that nested block. That is why you see parts either too close to one another or too far apart.
If you post an imperial drawing containing the imperial mvblocks that misbehave when being added to an imperial drawing, we could continue the conversation and perhaps involve Autodesk technical experts. I suggest you post this as a potential bug at www.autodesk.com/submitbug and attach the drawing and a reference to this thread.
@Anonymous wrote:Thanks. I did your recomedation but it doesn't work, I dont' know what's happening. When I insert a new mvblock, it deforms, but when I insert it from another drawing (an adt 2007 one) it doesnt' deform.
You may find this blog article
http://architects-desktop.blogspot.com/2013/05/aca-imperial-mvb-in-metric-drawing.html
and/or this Discussion Group thread
http://forums.autodesk.com/t5/AutoCAD-Architecture/Blocks-corrupted/td-p/3936452
of interest. Based on what I saw when the I_Appl_Refrig_Side-Side Multi-View Block [MVB] is inserted into a millimeter-based drawing, the MVBs that are giving you trouble probably make use of unit blocks in the 3D block. The scaling for the difference in units gets applied within the unit block itself, so the instance increases in size correctly, but the location of the unit block insertion point relative to the parent block's insertion point remains unchanged, rather than being made 25.4 times greater, which results in the 3D block being incorrect.
You can start with the inserted imperial content and redefine the view blocks as needed to create an equivalent metric block, as outlined in my responses in the Discussion Group thread. Once you understand what is happening, it is fairly easy to redefine the blocks.
