I'm and english mother tongue ACA user but working in a french environment.
Is it possible to have french data, ie labels, roomtags, section info etc but keep autocad english?
Giles
If you prefer to interact with ACA in English, then be sure to choose English when you install. Depending on how your license is set up, you may be able to deploy multiple languages but each deployment uses a single language. Inventor supports language packs but not ACA.
I imagine that choosing English might disable your French spell check but entering information such as room names, text, and other data shouldn't be affected if you use an English version to do French work. Number formatting such as use of decimal points or commas might be a sticking point.
This link might or might not help you.
