Hi Folks
in ACA 2013 was able to edit text to have two different hights in text IE .. First line of text 250 and second line of text 150... Something i use a lot of.
In ACA 2015 i cant seem to be able to do this, the editing ribbon doesnt seem to be complete. Perhaps im missing something? I have attached an image hereto.
So to recap. Im trying to edit mText with two different heights of text in one mText.
thanks kindly
Roo
Solved by Victoria.Studley. Go to Solution.
In the US here. Try putting your taskbar at the bottom instead of the right. I've never seen ACA compress the ribbon panels leaving that much space on the right. It appears that your profile is a unique one. Perhaps your ribbon has been gutted in that profile.
The one panel that is open is the one that should contain the text height widget and its not there. I agree that a reinstall might fix your problem.
Hi Roo,
This looks an awful lot like the following known issue in AutoCAD Architecture 2015, caused by migrating settings from a previous version:
Blank tools on Text Editor contextual tab in AutoCAD Architecture or AutoCAD MEP
Did you migrate any settings from a previous version of the software? If so, please try to solution here, and let us know if the tools return to the contextual ribbon.
Thanks so much for that. That fixed it perfectly.
Really appreciate your help....
thank you to all who responded, muchly grateful 😉
