AutoCAD Architecture General Discussion
2 Kudos
Post 1 of 17
MSLTSCALE Change in Multiple Drawings
209 Views, 16 Replies
11-27-2012 07:31 AM
Is there any way to change the msltscale variable to 1 and the scale to 1/4"=1'-0" in multiple drawings without opening each and doing it all manually?
Thanks for the help
15 Kudos
Post 2 of 17
Re: MSLTSCALE Change in Multiple Drawings
11-27-2012 07:54 AM in reply to: forseyc
Script
2 Kudos
Post 3 of 17
11-27-2012 08:14 AM in reply to: leothebuilder
I've never used script.  Can you give me a little more info on it?
15 Kudos
Post 4 of 17
11-27-2012 08:23 AM in reply to: forseyc
If you are new to autocad scripting, there are script generators available on the internet.
Dotsoft has "Super Script" which cost 50 bucks and is well worth it. There are others as well.
2 Kudos
Post 5 of 17
11-27-2012 08:25 AM in reply to: leothebuilder
Would a LISP routine be considered a script?  I see ACA incoprorates a LISP editor in the software.
15 Kudos
Post 6 of 17
11-27-2012 08:30 AM in reply to: forseyc
Lisp is different from script, and what you need is a batch script that can open cad files, set the MSLTScale, save the file and close the file.
Do a search on Autodesk site for ScriptPro.
It would do what you want and is free (I think)
2 Kudos
Post 7 of 17
11-27-2012 08:35 AM in reply to: leothebuilder
Great - I'll give that a try.  I tell you - its tough to manage all the houses we have and draw each one per customer selections and still try and improve my performance and keep up with technology and improve the standards of my department... When will the mayhem end for a single employee to handle all of this?  Come on economy!
15 Kudos
Post 8 of 17
11-27-2012 08:38 AM in reply to: forseyc
Ohhh.....stop grumbling and get on with it !:smileyhappy !   :-)
By the way...don't forget to set the MSLTScale in your template file ! (ant any other setvars you want)
2 Kudos
Post 9 of 17
11-29-2012 07:53 AM in reply to: leothebuilder
Great!  Script Pro is free and works great.
Here was my script:
CTAB
MODEL
MSLTSCALE
1
CANNOSCALE
1/4" = 1'-0"
_zoom
_extents
_qsave
_close
The only thing I want to change now is to be able to switch layout tabs and zoom extents in each - from my research it looks like I'll have to do some LISP routine - which I don't know how to do....
15 Kudos
Post 10 of 17
11-29-2012 08:16 AM in reply to: forseyc
TILEMODE = 0 sets the environment to Paper Space.
TILEMODE = 1 sets the environment to Model Space.
This should work in a script.
