AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Moving ACA to another computer
1 REPLY 1
PhilvK
243 Views, 1 Reply
I’m putting ACA 2010 onto a new computer and want to use the same setups and workspaces I have already created. I’ve done this before, got lucky because it worked, but I don’t how I did it.  Does anyone know what CUI or CUIX files I need to look for to copy and put on the new computer? Thank you!.
1 REPLY 1
pendean
in reply to: PhilvK
Did ACA2010 also install Migration Tools on both machines, old and new? Start button in Windows, Autodesk Folder, check it out if it did. Import and Export options.
Also, how organized were you with your customizations: keep everything uniquely named and in unique folders, or just change the core programs as needed with no tracking? Helps to know if you need to do a manual reinstall.
”Boost
