I have been working with Autodesk Architecture 2015 for the past month on a school project. The project that I (and a couple other students) are working on is modeling a real life building in Architecture using drawings given to us from a manager of the building. The dimensioned drawings that we get from him are not always the best, and sometimes we have to make up a dimension to make everything fit well. Twice now, I have had to move about 10 walls to make this work, and instead of using something simpler, I just redrew all of the walls to make it fit. Now I have 9 walls and 2 columns that are currently all properly aligned to eachother, but are 5' 5.25" off from the rest of the building. After looking through most of the menus in the program, I cannot seem to find a tool to move multiple objects at once.
Long story short: I am wondering if there is some tool that I can use to shift/move all of these objects (hopefully at once) to the correct location?
~Ean M.
Junior at the Dayton Regional STEM School
Solved by dbroad. Go to Solution.
Stretch or move?
After selecting objects, enter the displacement and hit enter key for second point.
To answer your question, I am wanting to move them all a certain distance (to be exact, the distance is 5'5.25"). Also, Where is the input field for the displacement number?
It wasn't really a question. It was really an indication of a choice that you need to make. (Move or stretch). They both have advantages. If you don't understand what a displacement is, you really need to refer to a textbook or the help files as they are better described there than I can post here.
Here is a link to a simple explanation.
http://www.dummies.com/how-to/content/how-to-use-the-move-command-in-autocad-2014.html
Thank you very much for the reference to the dummies.com page, it answered my question fully. Before when I had used the move tool, I only thought it could freely move the objects around, but now I see how to actually move the objects in a reasonable fashion.
