Using the QLeader command gives you that option.
Issue the command, read the command line for the options list and you can
select spline there.
I've never looked at how it relates to the dimstyle.
wrote in message news:6302114@discussion.autodesk.com...
Seems that autodesk is hiding more and more in the properties dialog or
ribbon.
Does anyone know what the command line input would be to turn a Leader
Line into a Spline?
The only way I've been able to do it is throught he prop dialog box, I'd
really like to set up a dimension type where the spline is standard.
If you are uncertain of what I am describing, check out the image
