I would think that it would use the same template as QNEW, but have never experimented to see if that is the case.
I believe you can put a /t switch in the target string and then specify a template file path/name after the switch.
The /ld switch tells AutoCAD to load the AecBase.dbx file, which is the one file that needs to be loaded to make ACA, ACA (or AMEP, AMEP), rather than just AutoCAD.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
