AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
math on command line issue
2 REPLIES 2
tcrish
839 Views, 2 Replies
Hello All,
In ACA, offset command, I can enter 3/2 on the command line to get a result of 1.5 offset.  If I enter 3.5/2 on command line, it won't give me 1.75.
Am I not inputing this correctly?  My math skills are ancient.  Trying to multiply doesn't work either, like 3*2.
Can anyone tell me what I'm doing wrong or a setting I need to change?
Tom
2 REPLIES 2
David_W_Koch
in reply to: tcrish
AutoCAD will not accept decimals when keying in a fractional amount.  For your example, enter 35/20, and you will get 1.75.
I am not aware that multiplication was ever a direct key-in option (vague memories of the tablet menu having an asterisk in the numeric input section try to solidify but vanish before fully forming).  You can use a LISP expression:  (* 2 3).  Typing 'QC should bring up the QuickCalc dialog, which will allow a multitude of calculator-like expressions to be entered to generate a numeric response on the Command: line.
If you want to stay on the Command: line, typing 'CAL and then pressing the Space Bar or ENTER key, followed by 2*3 and Space Bar/ENTER key will also work.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
tcrish
in reply to: David_W_Koch
Thanks, David,
I never did math on the command line before, after all these years I never needed to.  Your suggestions are working great.  There is always something for me to learn everyday. Smiley Very Happy
Thanks again,
Tom
”Boost
